Če ima še kdo probleme s tem mislim, da je tu rešitev. Odptrete eng datoteko in vnesite pod Break vrednost 0.0e0N 0.0e0N. Sem spodaj označil z rdečo kje je v eng datoteki najdete to.
Več o tem pa tu http://badlandsproject.mywowbb.com/forum6/672.html
SIMISA@@@@@@@@@@JINX0D0t______
Wagon ( FF_FRED
Type ( Freight )
WagonShape ( FF_FRED.s )
Size ( 0.1m 1.4m 0.1m )
Mass ( 1.1t )
InertiaTensor ( Box ( 0.2m 1.4m 0.2m ) )
Coupling (
Type ( Automatic )
Spring (
Stiffness ( 1e6N/m 5e6N/m )
Damping ( 5e6N/m/s 5e7N/m/s )
Break ( 0.0e0N 0.0e0N )
r0 ( 2cm 2cm )
Velocity ( 0.1m/s )
Adheasion ( 0.2 0.4 2 0 )
DerailRailHeight ( 4cm )
DerailRailForce ( 2.5*100t )
DerailBufferForce ( 800kN )
Friction (
10N/m/s 0 1mph 1N/m/s 1.8
5.1N/rad/s 1 -1rad/s 0 1
BrakeEquipmentType( "Triple_valve, Auxilary_reservoir, Emergency_brake_reservoir" )
BrakeSystemType( "Air_single_pipe" )
MaxBrakeForce( 1kN )
EmergencyBrakeResMaxPressure( 90 )
TripleValveRatio( 2.5 )
MaxReleaseRate( 2.27 )
MaxApplicationRate( 1.717 )
MaxAuxilaryChargingRate( 1 )
EmergencyResCapacity( 2.604 )
EmergencyResChargingRate( 1 )
BrakeCylinderPressureForMaxBrakeBrakeForce( 64 )
Lights ( 1
Light (
comment( Flashing rear end light )
Type ( 0 )
Conditions (
Unit ( 3 )
Cycle ( 0 )
FadeIn ( 0.1 )
FadeOut ( 0.1 )
States ( 2
State (
Duration ( 0.15 )
LightColour ( FFFF1100 )
Position ( 0.271 1.23 -0.1 )
Azimuth ( -180 -180 -180 )
Transition ( 0 )
Radius ( 0.4 )
State (
Duration ( 0.85 )
LightColour ( 00000000 )
Transition ( 0 )
Radius ( 0.4 )
Inside (
PassengerCabinFile ( FF_Fred.s )
PassengerCabinHeadPos ( 0 2.2 0 )
RotationLimit ( 180 180 180 )
StartDirection ( 0 0 0 )
