Ukazi za vožnjo vlaka
Odgovor Napisal/-a Nejc »
Pozdrav!!
Prosim, če mi kdo napiše ali poišče v slovenščini ali nemščini vse ukaze za vožnjo vlaka s tipkovnico (najbol me muči zaviranje s tipkovnico). Do divga odjemnikov toka, do vžiga lokomotive, peskanja, brisalcev, potrditve ASN-jov, itd.
S kero tipko se aktivira budnik?
Hvala za informacije!
Prispevkov: 2161
Pridružen: 17.08.2006, 8:57
Kraj: Brežice
Odgovor Napisal/-a Brižitka 363 »
Na začetku, kjer si lahko ogledaš lokomotive in vagone, tam sprobaj vse tipke.
Trainz
Prispevkov: 102
Pridružen: 27.12.2005, 23:46
Odgovor Napisal/-a Trainz »
Za zaviranje niso dodeljene vse tipke za vse komande , ki so mogoče.
Vlakci so kul
Trainz
Prispevkov: 102
Default dodeljene tipke:
driver
train_camera_forward plus
train_camera_backward minus
train_dcc_down x, comma
train_dcc_up w, fullstop
train_dcc_stop s, slash
train_dcc_handbrake a, apostrophe
train_cabin_brake_release q, KP9, kppgup
train_cabin_brake_lap z, KP6, kpright
train_cabin_brake_application a, KP3, kppgdn
train_cabin_brake_emergency pause
train_cabin_brake_1 null
train_cabin_brake_2 null
train_cabin_brake_3 null
train_cabin_brake_4 null
train_cabin_brake_up null
train_cabin_brake_down null
train_cabin_indbrake_toggle e, KP4, kpleft
train_cabin_indbrake_bail d, KP0, kpins
train_cabin_throttle_up w, KP8, kpup
train_cabin_throttle_down x, KP2, kpdn
train_cabin_throttle_0 s, KP5, kpclear
train_cabin_throttle_1 null
train_cabin_throttle_2 null
train_cabin_throttle_3 null
train_cabin_throttle_4 null
train_cabin_throttle_5 null
train_cabin_throttle_6 null
train_cabin_throttle_7 null
train_cabin_throttle_8 null
train_cabin_rev_forward f, KPstar
train_cabin_rev_backward r, KPslash
train_cabin_rev_neutral null
train_cabin_rev_toggle null
train_cabin_dyn_traction null
train_cabin_dyn_neutral null
train_cabin_dyn_brake null
train_cabin_dyn_toggle c, KP7, kphome
train_cabin_shovel_coal space
train_cabin_coalman_wave shift space
train_cabin_fans shift f
train_cabin_firebox_door_toggle KP1, kpend
train_cabin_regulator_up w, fullstop, KP8, kpup
train_cabin_regulator_down s, slash, KP2, kpdn
train_cabin_reverser_up f, KPstar
train_cabin_reverser_down r, KPslash
train_cabin_injector_up i
train_cabin_injector_down o
train_cabin_blower_up n
train_cabin_blower_down shift n
train_cabin_aws_reset alt space
train_cabin_aws_isolate alt 1
train_cabin_aws_activate alt 2
train_cabin_tpws_reset alt 3
train_cabin_tpws_isolate alt 4
train_cabin_tpws_activate alt 5
train_cabin_tpws_override alt 6
train_cabin_dra_on alt 7
train_cabin_dra_off alt 8
train_cabin_emergency_stop alt 9
train_cabin_master_switch_on alt 0
train_cabin_master_switch_off alt 0
train_cabin_engine_on alt [
train_cabin_engine_off alt ]
train_cabin_panel_lamp_test alt \
train_cabin_vigilance_foot_pedal alt tilde
train_cabin_wipers_on alt comma
train_cabin_wipers_off alt period
train_cabin_hardware_0 alt ;
train_cabin_hardware_1 alt '
train_headlight_toggle l
train_pantograph_toggle KP1, kpend
train_horn h, KPplus
train_sand v, KPminus
train_bell b
camera_up up
camera_down down
camera_left left
camera_right right
camera_zoom_in pageup
camera_zoom_out pagedown
camera_mod_control leftcontrolkey, rightcontrolkey
camera_mod_shift leftshiftkey, rightshiftkey
hud_consist_toggle null
hud_help_toggle ctrl h
camera_internal 1
camera_external 2
camera_tracking 3
camera_roaming 4
camera_prev leftbracket
camera_next rightbracket
camera_prev_fast ctrl leftbracket
camera_next_fast ctrl rightbracket
cmd_metric_toggle g
mode_decouple_toggle ctrl d
cmd_close escape
cmd_wireframe_toggle ctrl w
cmd_truewireframe_toggle alt w
cmd_findobject ctrl f
mode_map_toggle m, ctrl m
cmd_pause p
cmd_help F1
hud_interface_toggle F5
hud_driverbar_toggle F6
hud_buttonbar_toggle F7
hud_customhud_toggle F8
hud_controls_toggle F9
cmd_save ctrl s
cmd_load ctrl l
hud_objective_toggle enter
cmd_tuning ctrl t
debug_log_camera_angle ctrl f7
debug_show_autopilot_signal alt home
train_reverse_heading alt c
cmd_script_objectives k
toggle_next_junction j
toggle_prev_junction ctrl j
driver_1 ctrl 1
driver_2 ctrl 2
driver_3 ctrl 3
driver_4 ctrl 4
driver_5 ctrl 5
driver_6 ctrl 6
driver_7 ctrl 7
cmd_show_commodities_panel
cmd_show_waybills_panel
cmd_stop_schedule
cmd_continue_schedule
cmd_abandon_schedule
cmd_get_off_train
cmd_toggle_headtracker alt h
surveyor
cmd_newmap ctrl n
cmd_loadmap ctrl l
cmd_savemap ctrl s
cmd_editmap ctrl e
cmd_options ctrl o
cmd_tuning ctrl t
cmd_minimap ctrl m
cmd_profiles ctrl p
cmd_rules ctrl r
cmd_copy ctrl c
cmd_paste ctrl v
hud_interface_toggle ctrl space
hud_contextual_info_toggle alt o
mode_topology F1
com_height_up u
com_height_down d
com_height_adjust a
com_cursor_minus minus
com_cursor_plus plus
com_height_sensitivity_minus leftbracket
com_height_sensitivity_plus rightbracket
com_height_get g
com_height_use h
com_plateau p
com_add_water w
com_delete_water q
com_adjust_water_height e
com_extend_section x
com_displacement_rotation_minus shift leftbracket
com_displacement_rotation_plus shift rightbracket
com_displacement_scale_minus ctrl leftbracket
com_displacement_scale_plus ctrl rightbracket
com_select_box b
com_displace_apply f
com_cancel_selection d
mode_paint f2
com_texture_rotation_minus leftbracket
com_texture_rotation_plus rightbracket
com_texture_scale_minus ctrl leftbracket
com_texture_scale_plus ctrl rightbracket
com_cursor_size_minus minus
com_cursor_size_plus plus
com_paint_get g
com_fill_grid_texture l
com_select_box b
com_select_fill f
mode_objects f3
com_object_filter o
com_spline_filter s
com_object_name_minus minus
com_object_name_plus plus
com_object_add a
com_object_move m
com_object_rotate r
com_object_get g
com_object_delete d
com_object_name n
com_object_adjust_height h
com_object_spline_split q
com_object_spline_height h
com_object_spline_remove_vertex x
com_object_spline_insert i
com_object_spline_smooth s
mode_tracks f4
com_track_spline_filter t
com_track_object_filter y
com_track_trackmark_filter v
com_track_name_minus minus
com_track_name_plus plus
com_track_add a
com_track_move m
com_track_rotate r
com_track_get g
com_track_delete d
com_track_straighten b
com_track_toggle_junction j
com_track_renaming_stuff n
com_track_split q
com_track_spline_height h
com_track_spline_remove x
com_track_spline_insert i
com_track_spline_smooth s
com_track_get_gradient j
com_track_apply_gradient k
com_track_get_curve l
mode_world f6
com_world_clock_add a
com_world_clock_move m
com_world_clock_delete d
com_world_clock_red_minus shift minus
com_world_clock_red_plus shift plus
com_world_clock_green_minus ctrl minus
com_world_clock_green_plus ctrl plus
com_world_clock_blue_minus alt minus
com_world_clock_blue_plus alt plus
com_world_clock_minus minus
com_world_clock_plus plus
com_world_weather_minus leftbracket
com_world_weather_plus rightbracket
com_world_environment_minus ctrl leftbracket
com_world_environment_plus ctrl rightbracket
com_world_origin_add o
com_world_origin_find f
com_world_origin_edit e
com_menu_undo ctrl z
com_menu_redo ctrl y
com_bookmark_1 1
com_bookmark_2 2
com_bookmark_3 3
com_bookmark_4 4
com_bookmark_5 5
com_bookmark_6 6
com_bookmark_7 7
com_bookmark_8 8
com_bookmark_9 9
com_bookmark_10 0
com_bookmark_set_1 ctrl 1
com_bookmark_set_2 ctrl 2
com_bookmark_set_3 ctrl 3
com_bookmark_set_4 ctrl 4
com_bookmark_set_5 ctrl 5
com_bookmark_set_6 ctrl 6
com_bookmark_set_7 ctrl 7
com_bookmark_set_8 ctrl 8
com_bookmark_set_9 ctrl 9
com_bookmark_set_10 ctrl 0
com_bookmark_clear_1 ctrl shift 1
com_bookmark_clear_2 ctrl shift 2
com_bookmark_clear_3 ctrl shift 3
com_bookmark_clear_4 ctrl shift 4
com_bookmark_clear_5 ctrl shift 5
com_bookmark_clear_6 ctrl shift 6
com_bookmark_clear_7 ctrl shift 7
com_bookmark_clear_8 ctrl shift 8
com_bookmark_clear_9 ctrl shift 9
com_bookmark_clear_10 ctrl shift 0
com_menu_wireframe F9, ctrl w
com_menu_menubar F10
com_menu_help F12
mode_tools F5
com_tools_place_camera a
com_tools_move_camera m
com_tools_delete_camera d
com_tools_place_ruler r
com_tools_move_ruler t
com_tools_delete_ruler y
com_tools_paste_height s
com_tools_paste_rotation_minus leftbracket
com_tools_paste_rotation_plus rightbracket
com_tools_paste_height_relative l
com_tools_select_box b
com_tools_copy_paste p
com_tools_cancel_selection x
mode_trains F7
com_train_filter t
com_consist_filter c
com_train_name_minus minus
com_train_name_plus plus
com_train_add a
com_train_move m
com_train_rotate r
com_train_get g
com_train_delete d
com_train_properties p
com_train_change_heading h
com_train_decouple x
cmd_quick_drive ctrl f2
cmd_cam_fly alt u
cmd_cam_walk alt y
standard_dialog
std_save s, ctrl s, enter
std_dont_save d, ctrl d
std_no_save enter, e, ctrl e, d, ctrl d
std_cancel escape
std_new n, ctrl n
std_load enter
std_ok enter, space
std_reset r
std_yes enter,y
std_no escape,n
menu
main_driver d
main_surveyor s
main_railyard r
main_scenarios e
main_exchange x
main_credits c
main_quit escape, q
svyr_mainmenu escape, m
svyr_new n
svyr_delete d
svyr_accept enter
svyr_trainzmap t
drvr_mainmenu escape, m
drvr_panel tab
drvr_delete d
drvr_info i
drvr_accept enter
scen_back escape, m
scen_accept enter
yard_mainmenu escape, m
yard_favorites f
yard_info tab
yard_horn h
yard_lights l
yard_pants p
yard_interface_toggle ctrl space
yard_close ctrl w, ctrl q
minimap
minimap_bg alt b
minimap_gradients alt g
minimap_junctions alt j
minimap_signals alt s
minimap_triggers alt t
minimap_trackmarks alt m
minimap_industries alt i
minimap_namedobjects alt n
minimap_objects alt o
minimap_consists alt c
minimap_ts_labels alt l
Keybord.txt najdete v mapi \TRS2006\Settings
Vlakci so kul
Prispevkov: 12687
Odgovor Napisal/-a Dolfe »
Trainz napisal/-a:Default dodeljene tipke:
driver
train_cabin_brake_lap ..................................................................................................................................................................................................
Uaaaaaaaaaaaa! Toliko ukazov v realnem življenju nima niti VMR. (mednarodna vesoljska postaja). Slika
bojan
Prispevkov: 731
Pridružen: 15.01.2006, 19:54
Odgovor Napisal/-a bojan »
Dolfe napisal/-a: Uaaaaaaaaaaaa! Toliko ukazov v realnem življenju nima niti VMR. (mednarodna vesoljska postaja). Slika
Ufff, a sedaj vidiš kol'k si šele ti dober, ki te stvari obvladaš "in real" ne samo na nekem pc-ju Slika :mrgreen: :mrgreen: :mrgreen:
LPB
thomcro
Prispevkov: 610
Pridružen: 20.08.2006, 0:14
Kraj: Rijeka, Hrvatska
Odgovor Napisal/-a thomcro »
Ovo što je Trainz napisao za TRS2006, vrijedi i za TRS2004. Provjereno!!! :cry1
Pozdrav iz Rijeke
Prispevkov: 12687
bojan napisal/-a:
...... X 9 serij lokomotiv........... :shock:
:idea: Psssst...... :-$ Hhhkkhmmm,.....a se bo kej pri plači poznal? :-$ [-o<
Prispevkov: 2161
Kraj: Brežice
Tisti, ki ste strojevodje, je tudi na pravih lokomotivah tako veliko ukazov?
Prispevkov: 12687
Brižitka 363 napisal/-a:Tisti, ki ste strojevodje, je tudi na pravih lokomotivah tako veliko ukazov?
Seveda! še dvakrat več jih je. In vse to je treba obvladati tudi ob polnoči. :lol:
Ni tako strašno. V RL se dela veliko bolj na "handgetrib" in po občutku.
Človek je nezamenljiv. press
Trainz
Prispevkov: 102
No, ni tako hudo. Igra ima 2 načina upravljanja z vozili ( to niso samo lokomotive, lahko so tudi ladje, letala, helikopterji in avtomobili).
Prvi način je v CAB modu, kjer upravljaš vlak z ročicami v kabini. To lahko počneš s klikanjem po ročicah in stikalih ali pa z bližnjicami na tipkovnici. Te komande so v zgornjem spisku pod 1.poglavjem Driver.
Drugi način je DCC mod. V tem načinu so spet bližnjice na tipke, Gre za upravljanje od zunaj, nekako na daljavo in ne moreš upravljati z ročicami v kabini.
Nadalje so komande ( bližnjice) za ukaze v Surveyour mod-u, kjer ustvarjaš routo in postavljaš vozila na proge in jim dodajaš komande, strojevodje, pravila......itd.
Torej za samo upravljanje lokomotive iz kabine , rabiš v bistvu sam nekaj tipk. Ne bom vseh našteval, saj so zgoraj lepo napisane. Tam se lahko tudi vidi, da za nekatere komande še niso privzete tipke ( kot na primer,dinamične zavore).
Da poženete lokomotivo v default načinu iz igre ( to je arkaden način) je potrebno le teh nekaj komand. Izberite CAB način.Postavite ročico reverserja na forward( F) , popustite zavore (Q), dodajte gas ( W). Za zaustavljanje pa gas na nulo (S), zavore ( A) in emergency zavore (Y).... tako za začetek bo dovolj
Vlakci so kul
Trainz
Prispevkov: 102
No še nekaj, vem kaj boste pogrešali v default igri v CAB modu.
Obvestila o omejitvah , kilometrovnik, padec ali vzpon proge...
Te stvari niso default, se pa v surveyour-ju najdejo pod ikono knjige zgoraj levo. Tu treba dodati ( Edit) pravilo ( Rules) Show variable, ki ga najdete v spustnem meniju med drugimi dobrotami, ki se lahko dodajo v TRS
V desnem zgornjem kotu sebo v Driver načinu pojavilo okno , kjer vidite gradient, odometer in naslednjo omejitev hitrosti ( lahko pa tudi še kaj drugega)
Vlakci so kul
Prispevkov: 12687
Vseeno rabiš zraven vsaj tri življenja. :lol:
Trainz
Prispevkov: 102
No majhen popravek!
Da dodate Variable show morate še prej iz istega menu-ja dodati generalni ukaz Display custom HUD. To pa zato, ker custom HUD omogoča tudi druge dodatne parametre....
Pa še nekaj, jaz osebno ne rabim teh bližnjic, ker vse postorim s klikanjem. Tipkovnico rabim samo za obračanje pogleda in še to samo smerne tipke. Ni kaj, vaja dela mojstra. Je pa res da je Space invaders lažja igra. Rabiš smerni tipki levo-desno in s Space-om nažigaš po vesoljčkih. No za ene je še to pretežko in se ne umaknejo bombicam.....
Vlakci so kul
