PTG Tours "The Slovenian Spanka"
pwormald
Kurjač
Kurjač
Prispevkov: 48
Pridružen: 15.02.2009, 16:43
Kraj: Chesterfield
OdgovorNapisal/-a pwormald » 08.06.2009, 20:43
Provisional timetable of our special train running 17-22 June is on PTG Tours web site. I hope you can take photos of our train please :)
http://www.ptg.co.uk/tours/p-PTG-AN-12-5-09.doc
We use 644, 661 and 664 on 4 "Klasika" cars
Prispevkov: 1293
Pridružen: 05.05.2006, 18:25
Re: PTG Tours "The Slovenian Spanka"
OdgovorNapisal/-a 664-111 » 08.06.2009, 23:39
tell me what series will be on the train for Ljutomer-Radgona line? :D:D
Matic
pwormald
Kurjač
Kurjač
Prispevkov: 48
Kraj: Chesterfield
OdgovorNapisal/-a pwormald » 09.06.2009, 7:45
664-111 napisal/-a:tell me what series will be on the train for Ljutomer-Radgona line? :D:D
We use 644 + 4 Klasika cars :)
andersley
Prispevkov: 993
Pridružen: 05.03.2008, 19:44
Kraj: Ptuj, Slovenia
OdgovorNapisal/-a andersley » 09.06.2009, 8:21
Sounds like that will be an amazing trip! I think you will be covering more routes than we did last year using an Interrail pass!
I look forward to seeing the photographs from you, Phil, and others who see the train. :D
pwormald
Kurjač
Kurjač
Prispevkov: 48
Kraj: Chesterfield
OdgovorNapisal/-a pwormald » 09.06.2009, 8:27
andersley napisal/-a:Sounds like that will be an amazing trip! I think you will be covering more routes than we did last year using an Interrail pass!
We are covering four normally "freight only" bits of track, so it will be a great trip :)
Prispevkov: 1293
OdgovorNapisal/-a 664-111 » 09.06.2009, 10:39
pwormald napisal/-a:We use 644 + 4 Klasika cars :)
Thanks for the info :D it will be great to see to se a pasenger train on this line :D
Matic
OdgovorNapisal/-a milchy » 09.06.2009, 14:38
Matic, saj je videti potniški vlak na relaciji Ljutomer - G. Radgona vsako leto v času radgonskega sejma - sicer samo Fiat, a bolje to kot nič :)
Prispevkov: 1293
OdgovorNapisal/-a 664-111 » 09.06.2009, 19:23
milchy napisal/-a:Matic, saj je videti potniški vlak na relaciji Ljutomer - G. Radgona vsako leto v času radgonskega sejma - sicer samo Fiat, a bolje to kot nič :)
Že že :D :D ali v mislih sem imel klasično kompozicijo :oops: te pa tam že en lep čas ni bilo :D
Matic
363
Prispevkov: 1413
Pridružen: 06.09.2006, 18:28
OdgovorNapisal/-a 363 » 29.04.2010, 19:50
Letos ponovno pridejo Angleži. Tukaj je potek potovanja:
http://www.ptg.co.uk/tours/SlovenianSpanka2010.pdf
Prispevkov: 6498
OdgovorNapisal/-a Gorchi » 29.04.2010, 21:47
Ohoho, tole bo pa tura, celo slovenski dizli se bodo našli na Avstrijskem koroškem 8) Tole bi bilo pa resnično za slikat, če bo res 8) 8) 8) 8)
OdgovorNapisal/-a milchy » 02.05.2010, 12:37
Gorchi napisal/-a:Ohoho, tole bo pa tura, celo slovenski dizli se bodo našli na Avstrijskem koroškem 8) Tole bi bilo pa resnično za slikat, če bo res 8) 8) 8) 8)
po planu naj bi jih prvi dan vlekla 664, drugi dan pa 644 .... (upajmo da res), po Hrvaški pa 2063 in 2132 (?) v Metliki pa jih bo prevzela španka 012
M.
AEE_Express
Prispevkov: 345
Pridružen: 16.03.2010, 11:24
OdgovorNapisal/-a AEE_Express » 02.05.2010, 13:43
ŠPANKA in REGAN bo vozi v Avstriji Celovec,Beljak,GRADEC in BRUCK ad MUR, tudi novice ;
http://www.fahrplancenter.com/RRR2010Slowenien.html 664 v avstriji BO !
Tomaž97
Prispevkov: 1705
Pridružen: 07.06.2009, 19:30
Kraj: Proga št. 62
OdgovorNapisal/-a Tomaž97 » 02.05.2010, 17:31
Mogoče kdo ve katera številka Španke bo pripeljala v Koper? :?:
Hvala za odgovore.
OdgovorNapisal/-a Dolfe » 02.05.2010, 20:05
Tomaž97 napisal/-a:Mogoče kdo ve katera številka Španke bo pripeljala v Koper? :?:
Hvala za odgovore.
Seveda! Vozila bo 644. :wink:
pwormald
Kurjač
Kurjač
Prispevkov: 48
Kraj: Chesterfield
OdgovorNapisal/-a pwormald » 12.05.2010, 18:29
To Koper this year we take 664 as we took 644 there last year! Probably with 664.119, but at moment this loco working in Maribor, so maybe another 664 instead?
In HZ we have approval to go to Bakar :o Is this the first passenger train to Bakar?
