Zvok diferenciala?zelencek napisal/-a:Kaj je tisti visoki zvok, ki postopoma narašča?
Ah ne, to je zvok menjalnika
Hallo.Paradezug napisal/-a:Good evening!
I have a question about the 711's, because i want to photgraph them!
Were are they driving around in wich area, do they have a fixed tour or a fixed train?
Yes, it's fixedParadezug napisal/-a:Thank you!
Is that the only fixed tour of the 711er?
Is that the only fixed tour with 711ers or are there some more?
With some luck you'll be able to catch the freshly painted 711-001/002, which can be seen around Ljubljana station relatively often these days.Paradezug napisal/-a:I have a question about the 711's, because i want to photgraph them!
Re 4/4 napisal/-a:Hallo.Paradezug napisal/-a:Good evening!
You can see train 711 every works day In Ljubljana at 15:15 when they go to Pragersko/Hodoš and every works day in Pragersko at 05:56 when they go to Ljubljana
Seen this sunday in Ljubljana on blind track waiting for new assignmentsodbijac napisal/-a:With some luck you'll be able to catch the freshly painted 711-001/002, which can be seen around Ljubljana station relatively often these days.Paradezug napisal/-a:I have a question about the 711's, because i want to photgraph them!
Nobenih nalog dokler ne zamenjajo menjalnika na 001....Gorchi napisal/-a:odbijac napisal/-a: Seen this sunday in Ljubljana on blind track waiting for new assignments
Hvala in oprostiAjznponar napisal/-a:Pred časom sem ravno to že vprašal (polinkan je že odgovor)zelencek napisal/-a:Baje se da pri 711 obrniti sedeže (eno dvojico). Kako se to naredi če se lahko?
