711
Prispevkov: 4531
Re: 711
OdgovorNapisal/-a igor72 » 14.06.2018, 14:25
TGV Lyria napisal/-a:Čakaj...
Hočeš reči, da lani vlak iz Pule NI imel veze iz Kopra (1604) oziroma je odpeljal prej iz Kozine proti Sežani, kot je Koprčan pripeljal?
Ne, vlak iz Pule je VEDNO čakal na 1604 v Kozini, in odpeljal ZA njim proti Sežani!
Takrat pa, ko smo vozili samo do Kozine, (3leta nazaj in +)smo včasih zbežali tudi pred 1604, če je le ta bil malo zamujen, ampak to je bila itaq strojna vožnja in je bila takrat veza za Gorico prestop v Divači!
Prispevkov: 1650
Re: 711
OdgovorNapisal/-a TGV Lyria » 14.06.2018, 14:56
igor72 napisal/-a:
Potem pa res ne vem, kaj se je dogajalo 25.8.2017, ko v Kozini po prihodu 1604 ni bilo ne duha ne sluha o zelencu iz Pule za Sežano.
Prispevkov: 11398
Re: 711
OdgovorNapisal/-a cokla » 14.06.2018, 15:52
Verjetno se je "dogajala" okvara....
Southern bear
Prispevkov: 7
Pridružen: 11.03.2018, 14:10
Re: 711
OdgovorNapisal/-a Southern bear » 21.04.2019, 11:54
Hi, does anybody know, on which connections I could take the 711, "Zeleni vlak" train? I heard there are just 5 of them, so the probability of getting on one is pretty small and that they are running only in the Prekmurje region. Are there any train connections, that are always run by the 711 train (like LP 3854/ LP 3858/ LP 3860...)?
They are supposedly very comfortable and I would really like to try one out.
I am not so good at writing in Slovenian so I will be writing in English. However I urge you to reply in Slovenian, because I understand it (I just can´t write it properly).
andre85
Prispevkov: 333
Pridružen: 11.04.2014, 19:36
Kraj: Freilassing
Re: 711
OdgovorNapisal/-a andre85 » 21.04.2019, 12:39
Če smo že pri tem kje je tista 711 ki ima modro shemo?
urban120
Prispevkov: 237
Pridružen: 10.05.2015, 19:05
Re: 711
OdgovorNapisal/-a urban120 » 21.04.2019, 14:15
Southern bear napisal/-a:Hi, does anybody know, on which connections I could take the 711, "Zeleni vlak" train? I heard there are just 5 of them, so the probability of getting on one is pretty small and that they are running only in the Prekmurje region. Are there any train connections, that are always run by the 711 train (like LP 3854/ LP 3858/ LP 3860...)?
Direct trains to Pula are always running with 711. I recommend you take one of those.
Tomaž97
Prispevkov: 1705
Pridružen: 07.06.2009, 19:30
Kraj: Proga št. 62
Re: 711
OdgovorNapisal/-a Tomaž97 » 21.04.2019, 15:49
urban120 napisal/-a:Direct trains to Pula are always running with 711. I recommend you take one of those.
Sploh ni zagotovljen..te dni vozi do Pule 713/715.
andre85
Prispevkov: 333
Kraj: Freilassing
Re: 711
OdgovorNapisal/-a andre85 » 21.04.2019, 16:10
No lahko bi rekli,da na slovenskih tirih vozi en del zgodovine Airbusa
Prispevkov: 1650
Re: 711
OdgovorNapisal/-a TGV Lyria » 21.04.2019, 16:16
Usually it is on RG 1641 from Hodoš to Ljubljana on Sunday.
Used to be IC 518/519 from Hodoš to Ljubljana and back, on weekdays. But it's currently not running due to the engineering works.
andre85 napisal/-a:Če smo že pri tem kje je tista 711 ki ima modro shemo?
Je spet zelena...
andre85
Prispevkov: 333
Kraj: Freilassing
Re: 711
OdgovorNapisal/-a andre85 » 21.04.2019, 18:20
Je spet zelena...
Škoda,ker bi barvno ustrezala k Flirtu in mu dala Kiss :)
Southern bear
Prispevkov: 7
Re: 711
OdgovorNapisal/-a Southern bear » 21.04.2019, 18:39
Thanks for responses :)
Kanarček715
Prispevkov: 54
Pridružen: 27.01.2014, 19:34
Re: 711
OdgovorNapisal/-a Kanarček715 » 14.11.2019, 7:17
Današnja zanimivost v Ljubljani: vlak LP 2218 (odhod iz LJ ob 6.45) je proti Kranju vlekel Zelenc. Je tako hudo pomanjkanje Siemenov (312)?
andrazon
Prispevkov: 507
Pridružen: 07.07.2011, 20:23
Re: 711
OdgovorNapisal/-a andrazon » 14.11.2019, 10:07
Tudi LP2407 je bil zadnje trikrat ko sem se peljal kar Moped ali Živa z vagoni, ponavadi pa dva tročlenska Siemensa
LP Andraž
Florjan
Prispevkov: 639
Pridružen: 16.11.2005, 18:56
Kraj: Šmartno pri Litiji
Re: 711
OdgovorNapisal/-a Florjan » 29.12.2019, 16:50
Čestitke Abrahamu! :D =D> Te dni je (tik pred božičem) je minilo 50 let ko so pripeljali "Mercedesa" v Ljubljano.
Prispevkov: 3582
Re: 711
OdgovorNapisal/-a Tin€ » 30.12.2019, 16:58
Florjan napisal/-a:Čestitke Abrahamu! :D =D> Te dni je (tik pred božičem) je minilo 50 let ko so pripeljali "Mercedesa" v Ljubljano.
Po desetletju in pol so potem popmozno najavili prihod petih novih garnitur zelenega vlaka (serija 713/715) katera ni bila niti bleda senca naspram seriji 711, če samo začnemo pri klimi.
Žal se vsakemu življenjski ciklus enkrat izteče in tako se počasi poslavljajo še zadnje garniture te serije. Upam, da bo vsaj ena garnitura odšla v muzej, da bi bila vozna je pa že skorajda nemogoče pričakovati. Ta serija je močno zaznamovala obdobje svojega službovanja na slovenskem in tudi na območju bivše države. Čas potovanja med Ljubljano in Beogradom je bil za današnje razmere znanstvena fantastika!
Po forumu brska: Google [Bot] in 5 gostov
