Decoder fitting in a series 36 2-10-0
totimato
Prispevkov: 615
Pridružen: 02.01.2009, 11:00
Kraj: Zg. Polskava
Re: Decoder fitting in a series 36 2-10-0
Odgovor Napisal/-a totimato »
Gorchi napisal/-a:Alan, You do not need to put more than 2-3 wires back to the loco. Therefore You can use some small connector which can be hidden either in tender, either in the loco. Now which connector to choose, that is different story. Usually the connectors have distance between pins approx 2,5mm while some time ago I have found a web site on eBay that sells connectors with 1,25mm spacing. Unfortunatelly the link has been erased but hopefully someone could provide us a web site selling such connectors.
Also a good idea was used by Rivarossi but they use 9 pin (!!) connector between loco and tender, also with such small space between pins.
Edit: here it is:
5er Set 5-polige Miniatur Steckverbinder - RM 1,27mm
Hi!
There are more than 3 wires...
1st situation - decoder in tender:
- 2 wires - front lights
- 2 wires - steam generator
- 2 wires - track pickup (could be left out)
2nd situation - decoder in locomotive:
- 2 wires - motor
- 2 wires - back lights
There is a 2 wire connector allready, so i would be adding a 4 wire connector, right?
This is how i see it (I could be wrong).
Regarding "Pin Strips and Sockets", if i'm not mistaken i just bought such a thing in HTE (they are in LJ and MB), cheap. For really small connectors you should check spare parts for GSMs - connector for motor for vibrator in GSM. If you wish i can take a picture of one i have - but its a 2 pin connector.
Best regards,
Totimato,
You do not need so many wires. Lights and steam generator share common wire, I think common +. Wires from the track go via the coupling between tender and loco. Thus You only need 3 wires:
- common +
- front lights -
- steam generator -
totimato
Prispevkov: 615
Kraj: Zg. Polskava
I stand corrected :)
flying scotsman
Prispevkov: 255
Pridružen: 16.01.2009, 13:38
Odgovor Napisal/-a flying scotsman »
Sound decoder fitted in my Roco br 58 (jz 36) :D
[youtube]http://www.youtube.com/watch?v=wvfZteGO ... er&list=UL[/youtube]
I am sorry for bad picture. :oops:
flying scotsman
Prispevkov: 255
...sem se odločil da tudi br 58 1919 zdigitaliziram... dekoder pa sem raje dal v "kotel".
andersley
Prispevkov: 993
Pridružen: 05.03.2008, 19:44
Kraj: Ptuj, Slovenia
Odgovor Napisal/-a andersley »
Excellent! Very realistic sounds. =D>
andrazon
Prispevkov: 510
Pridružen: 07.07.2011, 20:23
Odgovor Napisal/-a andrazon »
Like I can see, there's a motor inside the tender. Is that the onli motor, or is there alsaw a motor in locomotive.
LP Andraž
LP Andraž
andersley
Prispevkov: 993
Just the one motor in the tender. The locomotive 'free-wheels'. :)
