Sejem modelnih železnic nov. 2008
Thanks again Goran. I have emailed Mr Jocif - hope he speaks English!
No problem for me to get Tenshodo motor bogies.
Alan Curtis
http://www.andersley.co.uk/
The Black Beetles are more robust than the Tenshodo I have heard, which is good if the model is heavy as the axleboxes are plastic, but for a railcar I would think Tenshodo's would be fine. I have never used BB but Tenshodo ones I have used are very quiet. I would think that two motor bogies would be enough power for a railcar. I will use Tenshodo as the BB are very expensive.
Alan Curtis
Alan, thank You for this valuable information. I was thinking of buying two powered motor boogies so Tenshodo will be.
Mmg, dobil sem naslov še ene strani, kjer je moč nabaviti Black Beetle vozičke, če koga zanima:
http://home.waterfront.net.au/~sem/bbeetle.htm
Menda so tukaj precej cenejši kot na http://motorbogies.com/, niso pa v EU. Do 25 EUR pa se itak ni za sekirat
24 weeks! Oh well, I have plenty of other things to do whilst I am waiting.
Alan Curtis
Nagradno vprašane brez nagrade Kje so Black Beetle motorni vozički "doma" oz. ve kdo za zares proizvajalčevo stran? Namreč tale je res močna, da je dobavni rok 24 tednov. Ti definitivno nimajo recesije v firmi
Aja še informacija od g. Puklavca za podstavne vozičke Black Beetle):
kolesa: diski (brez špic)
razmak med osema (ang. wheelbase): 31 mm
premer kolesa: 10,5 mm
profil: 110
prenosno razmerje (ratio): 27:1 (za malce počasnejšo a močnejšo varianto) oziroma 15:1 (hitrejši in nekoliko tišji)
profil: 110
več fotoreprotaža slika sejem maket v ljubljani
Foto je 664.111 , bart in stojan.
link; http://3.bp.blogspot.com/_QPasVLHuQ7A/S ... h/1del.jpg
http://4.bp.blogspot.com/_QPasVLHuQ7A/S ... h/1del.jpg
http://2.bp.blogspot.com/_QPasVLHuQ7A/S ... h/2del.jpg
http://4.bp.blogspot.com/_QPasVLHuQ7A/S ... a00762.jpg
@dolfe, prosimo ne zbsrno od moj piši, to je fotoreportaža in fotografija je od tri osebi in zelo priden!
lp,Miro
lp,Miro
- Prispevkov: 946
Gomulka
Mislim, da bi bilo potrebno odpreti novo temo samo o gradnji Gomuljke, podobno kakor se je kasneje začela Gorchijeva o "medenini".
Sejem naj ostane sejem, koristni podatki o Gomulki in gradnji naj se zbirajo na drugem mestu!
To je sicer samo moje osebno mnenje.
Sebastian
I agree. A seperate topic for construction of a Gomulka would be very good. That way builders can benefit from each other's experiences.
Alan Curtis
