Sem mislil, da so zobate železnice izumrle, oziroma imajo samo še turistični pomen. Pa preberem, da Švicarski Stadler Rail gradi 7 velikih zobatih lokomotiv (41M€) za Brazilsko družbo MRS Logistica S.A. Namenjene bodo prevozu železne rude od Sao Paolo do pristanišča Santos. Upam, da bo kaj več podatkov.
Najzmoglivejša zobata lokomotiva
Re: Najzmoglivejša zobata lokomotiva
Evo nekaj podatkov:
PS.:
Opažam, da so črke iz naslova kar odpadle. A zna naslov kdo popravit?
LPLStadler:
The most powerful locomotive ever
The large Brazilian cargo company MRS Logística S.A. ordered the seven powerful rack-and-pinion freight locomotives from Stadler Rail mainly for use with heavy trains carrying iron ore. The freight line from São Paulo to the Santos docks is a 1,600-millimetre broad-gauge track with a 9-kilometre-long ramp, along which the rack runs. With a power of 5,000 kW, 700 kN tractive force at starting and a length of almost 18 metres per vehicle, they will be the largest and most powerful rack-and-pinion locomotives ever. Two of these locomotives in double traction will have a towing capacity of 750 tonnes on the 104‰ ramps, meaning they will be 50% more powerful than those currently in use.
The four-axle locomotives have two bogies, which in turn each have two pinion transmission systems engaging with the triple-lamella Abt rack. Support is provided by two separate adhesion transmission systems, which contribute about 25% of the traction as the train goes uphill. The regenerative ability of modern traction equipment also enables massive energy savings to be made on the 3 kV DC line.
PS.:
Na http://www.vlaki.info zmoremo in znamo vse. Urejeno.
Mod. Dolfe
- Prispevkov: 9511
Men pokaže slovenski črkovalnik (Spell checker) pri besedi NajzmoglivejšaDolfe napisal/-a:Ljubitelj napisal/-a:
Mod. Dolfe
(rdeče pomeni NAPAČNO )
železocestnik napisal/-a: Men pokaže slovenski črkovalnik (Spell checker) pri besedi Najzmoglivejša
Rdeče je pocahnano zaradi vpliva avtoritete.
Najzmogljivejša ..
Zato podčrta rdeče..
