Silvo Berdajs grozi ljudem na SŽ
Mičo
Prispevkov: 327
Pridružen: 11.07.2011, 19:00
OdgovorNapisal/-a Mičo » 29.03.2018, 19:49
LukaSLO
Prispevkov: 57
Pridružen: 13.07.2012, 11:59
Re: Silvo Berdajs grozi ljudem na SŽ
OdgovorNapisal/-a LukaSLO » 29.03.2018, 22:30
Očitno na SŽ poteka vojna, kjer se uporabljajo brutalne metode. Verjetno na obeh straneh. Sram jih je lahko!
https://www.24ur.com/novice/slovenija/s ... eznic.html
smok1
Prispevkov: 59
Pridružen: 21.12.2017, 15:56
OdgovorNapisal/-a smok1 » 30.03.2018, 17:13
A ni na tem forumu kar nekaj zaposlenih iz SŽ? Zakaj takšna tišina? :roll:
OdgovorNapisal/-a holding » 30.03.2018, 18:35
..."kdor molči, devetim odgovori"...... :mrgreen: ....pravi star slovenski pregovor....
kvak
Prispevkov: 303
Pridružen: 18.07.2009, 16:34
OdgovorNapisal/-a kvak » 09.04.2018, 15:48
strah?
trocken
Prispevkov: 611
Pridružen: 22.12.2009, 10:55
OdgovorNapisal/-a trocken » 09.04.2018, 21:40
kvak napisal/-a:strah?
Strah! Puhne gate!
Southern bear
Prispevkov: 7
Pridružen: 11.03.2018, 14:10
OdgovorNapisal/-a Southern bear » 10.04.2018, 10:23
Is this for real? Do I understand it right - a guy from the labor union at Slovenian railways is threatening with beatings, so employees are afraid to come forward and talk about the issue?
I thought Slovenia was a modern democracy. How is this even possible? Is he going to be prosecuted for his actions?
smok1
Prispevkov: 59
OdgovorNapisal/-a smok1 » 10.04.2018, 14:57
You understood it correctly. He is threatening that he is going to "fuck them up" (how you interpret that is up to you) if they don't join his side and from what what he is saying it's either his way or the highway.
He is currently "under investigation" and from what history tells us no actual actions will be taken against him. SŽ are one of the last few nests of villainy and corruption in the country, that is why the progress and development at the company is minimal.
mario
Prispevkov: 945
Pridružen: 03.04.2007, 13:13
Kraj: Na pravi strani Alp
OdgovorNapisal/-a mario » 10.04.2018, 19:46
Hahaha, uvdje su se i najhrabriji usrali :D
.... je napis znotraj WCja na ljubljanski železniški postaji ;-)
Southern bear
Prispevkov: 7
OdgovorNapisal/-a Southern bear » 13.04.2018, 18:10
smok1 napisal/-a:You understood it correctly. He is threatening that he is going to "fuck them up" (how you interpret that is up to you) if they don't join his side and from what what he is saying it's either his way or the highway.
Thank you for this information. I genuinely can not believe this. Sad.
BTW: you can reply in Slovenian, I understand it, just can not write it (look at my signature).
